New Stuff on Vehicles likes/dislikes
bruceb58
The 10 speed transmissions in the Ford and GM are sister transmissions from the same Ford/GM JV
In the half tons they are. GM and Ford developed their own 10 speeds in the 3/4T and up although they started with the half ton designs and they went in different directions on the heavy duty transmissions.
Pmt133
You hardly feel the shifts in a 10 speed. BTW, when you drove that bronco, it skips gears 2 and 4 unless you were in sport or trailer mode. F-150s do the same.
Interesting. My 22 f150 does not seem to skip 2 or 4 all the time. (Can watch it indicate each gear and feel each gear on acceleration in normal mode) seems to do it more in slow traffic or very light acceleration. The denali is so smooth I couldn't tell you if it does or doesn't as I really can't feel the shifts to count them.
bruceb58
If you accelerate at a normal rate, it will skip. If you accelerate higher, it might not skip.
jlh3rd
Master Chief Petty Officer
and
FLATHEAD
We have “ you pull it” salvage yards around here. Only way to go on parts like that.
Pmt133
I figured I'd cross check the same source for mine out of curiosity. They can be found used in the $200-$400 range. I guess when the vehicle is 100k that msrp makes sense.
Lou C
My point is:
Who asked for this? Blind spot monitoring
It’s a conspiracy guys, between the unelected bureaucrats and the auto execs. Good for them bad for consumers. While the feckless politicians crow about affordability!
bruceb58
My point is:
Probably one of the most important safety features!
Btw…politics has nothing to do with this so just stop with your nonsense.
Lou C
OK guys, have you looked at your car insurance premiums over the past few years? Notice anything different?
Whether it's politics or the auto companies, car insurance premiums have skyrocketed in the past 4-5 years and high tech expensive to fix vehicles, are an obvious cause.
matt167
Average GM tail or head light that is LED is $1,500 and modules hover around that cost.
