jovial_cynic
- Joined
- Jul 29, 2008
- 10
Hey folks -
I'm brand new to the boating scene, but I've been lurking through here for a little while to glean as much information as possible.
Here's the boat I recently picked up off craigslist for cheap:
The boat itself is in good shape - just a few chips here and there that I'm comfortable fixing. The boat apparently sat for about 8 years, and the engine hasn't been run in about 4 years, so it looks like I've got a little bit of work ahead of me.
The boat was brought in from canada, and according to the previous owner, it's a late 70's boat. The engine (not sure if it originally came with the boat) is a Johnson VRO 50.
As soon as I brought it home, I figured I'd at least check to see if the engine turned over, so I threw a battery on it and sure it, it cranked over just fine. A little sluggish, though... and even when jumping it from a live battery, it seems like there's a bad ground somewhere. It had a beast of a time cranking over...
Anyhow, I put some mixed oil in the gas tank to see if I could get it to fire up at all (after hooking up the water to the bunny ears, of course), and it actually fired up immediately. Now, having done some reading, I realize that the VRO is an auto-mixing system, so I might not have to pre-mix my fuel. However, I also know that trusting a sitting-for-4-years oil mixing system might not be the wisest idea, so I ignored it... but there may still be oil in the system that's also mixing with my pre-mix, effectively watering (oiling?) down my gasoline... which is no good.
So... what's the checklist of things I need to do to make sure my engine is good to go, provided that I've got little issues like the potential grounding problem, carbs that need to be de-gunked, etc., etc.? When you get a new boat with a mystery motor, what's the first thing you do?
