New to me '68 Johnson 6hp, comments?
kjdunne
Found a CD-25C long shaft that looks very good at an estate sale. It's complete, clean, and appears well cared for. The skeg is scuffed a bit but the rest of the paint is good and it has no rust or corrosion on it anywhere. I could not pass it up but have not really checked it out. It turns over OK with the rope and has compression. Only thing I see wrong is a broken choke knob, which acording to BRP website is still available.
Anyway, what's the general reputation of these motors? Any common problems I should be aware of? I'm assuming it's a 50:1 mix, correct? I'll start going over it as time permits, just looking for some basic info on it.
Thanks
ddwilson
Re: New to me '68 Johnson 6hp, comments?
50:1 is correct, I would suggest replacing the impeller, and drain and refill the lower unit then give it a try. May need to
rebuild the carb and fuel pump but if it was me would probably do the impeller and then see what happens
boobie
Hang on to it. It was a good motor.
edquade
I have a 1965 6 horse Evinrude, probably the most trustworthy boat motors I have ever had experience with if you take care of it.
kjdunne
Thanks for the replies, good to hear they were good motors. I'm buying a factory service manual and will get going on the impeller, gear oil, etc. If I run into problems or have questions, I'll start a thread. Thanks again.
