FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a Mercruiser Celebrity 210 v cuddy and I have a problem with my throttle. if I'm going forward is OK but when I'm going backward and I wanna put on neutral is not going smooth and prop is still running and boat going forward
Boats aren't like cars. Car manufacturers generally are also the engine maker, and offer a small range of their own engines as options. Boats builders use engine suppliers, for stern drives either Mercruiser or Volvo (who actually source their base engines from car makers :facepalm. So a boat may have a Mercruiser or a Volvo of either 4, 6 or 8 cylinder engine. Often it will be at the discretion of the initial purchaser.
Being a 1987 I would guess its an Alpha but would like confirmation. Also if its staying in gear and if it is an Alpha then it would be difficult to get it in neutral.
You can go from forward to neutral and things are OK, but when your in reverse and go to neutral its in forward?
lenarw79 your posting one thread after another all about the same boat which you just bought and not answering all the questions in the threads you previously posted. I think all these could be in one thread, you making matters worst for your self and us bouncing around.
Being a Celebrity 210 it should be an I/O, and your other thread and the noise you discussing is probably an alpha
Reading thru your different threads it appears you have an alpha drive, and the issue your having with shifting and drive staying engaged, I would say you need the lower shift cable replaced and adjusted.
I think these threads have been merged or closed as needed. lenarw79 Please try to keep your posts about this boat in one thread and in the right area of the forums so we can do a better job helping you. This thread will be retitled.
