NAVY LIFE
Thread starter- Joined
- Jul 23, 2011
- 37
Ok the background, powerhead is 1989 110 Johnson I bought has 90 psi on all 4 tested before mounted. I mated the powerhead to a 1987 90hp Evinrude.
New water pump, new thermostats carbs, rebuilt. On trial start fired right up took a few seconds to see water from teltale. A few minuts later overheat buzzer shut her down. Stream was week, pulled lower unit checked water pump had debries cleaned and reinstalled. Flushed motor out from below before installing lower unit. Wish I would have thought of that sooner. Pulled thermostats full of crap cleaned and reinstalled. Second time starting no overheat, cylinder heads a little hot to the touch but still not much pressure from the teltale and no over heat alarm.
My questions:
Why weak stream from teltale?
Water comming out from area behind where the anoid is located instead of from the prop.
See pic.
What is my next step??
Thanks,
Brian
And Joe's zip strip idea for the thermostats worked great!
My questions:
See pic.
Thanks,
Brian
