Re: new way to change engine oil?
If you pull the oil plug after you use your'e little pump thing, I think you still would still have around a half of a quart of dirty oil still left in the oil pan. I never have liked the idea of pumping 5 quarts of oil through the dip stick tube. I guess I would do it if my boat stayed in the water all the time. What I did was pull the drain plug and drain all the oil in the bilge. I then took my drain plug to the hard ware store and bought some pipe the same thread, I also bought a ball valve and a barb fitting that screws into the ball valve. When I change my oil, I run my boat on the muffs on the trailer until the engine gets up to operating temp, shut engine off, connect a piece of hose to my barb fitting, feed the hose through the plug hole, cut the safety wire on the ball valve, open valve and let the oil drain into my oil drainer. Before I did it this way I would always jack the trailer up like the post above and drain it in the bilge. Not that much of a mess, just wipe up what you can with rags and a couple cups of tide laundry detergent, and a water hose does trhe trick for me. I don't know, I just know I want all the dirty oil out of my engine when I change it. I would rather clean up a little mess in the bilge than have dirty oil mix with my new oil.
