Re: Newbie Here, Need some engine help... Please... 77' Johnson 35hp
Can you explain where you see discoloration? I want to know what to look for. To me it all looks the same... But I really don't know what to look for...
The motor never seized, it continued to run, I shut it down once I saw it was overheating. It also started right back up. In my experience (Automobile) if the motor seizes, everything stops working...
No, I'm not seeing the smoke come from inside the cover, you can see it clearly in the video what I'm referring too.
I will order a new head gasket tomorrow and install it this weekend.
As far as tightening the bolts to spec, the lower cover doesn't appear to be able to be dropped to allow full access to the lower head bolts. Is there a trick or secret I'm unaware of? There's no way my inch/lb torque wrench with a socket will fit down in there.
Thanks for everyone's help, I'm really impressed with the response I've had.
