no forward or reverse
jails
i have a 70 hp force mercury and was in 32 feet of water and i slowed the boat to fish but when i went to move a little the boat would not engage forward or reverse both cables are hooked up and the boat was running fine,when i engage the throttle in forward i can still spin the prop although it seems to get a little tighter when engaged than in neutral. any ideas??steve
Jeremy90bay
Re: no forward or reverse
could you here it engage at all? Spun prop?
jails
when the engine is off i can here it alittle but i can also spin the prop when in rev or forward by hand.is that normal to beable to spin prop when in forward
electric000
Hi,have had someone work the throttle while you looked at the shift rod to make sure it's moving,making sure your shift cable isn't broken?
john from md
Is the gear shift engaging and the boat not going or is the gear shift not moving. (throttle wouldn't move in this case)
John
