Hey folks,
I have an '82 Mercruiser 120 (2.5L) Based on my previous posts, it had sat for a couple of years before I got it. I have not been able to get fuel to the carb at this point. I changed the mechanical fuel pump yesterday and all the fuel lines as well since they were old auto rated fuel lines. It does have a Sierra water separator in line as well. I have cranked it for a while and still no fuel up to the carb when I crack the line at the carb. I had thought about possible a vent line clogged, so I have pulled the gas cap and still no fuel. I can blow in the line to the tank and get bubbles and I can also draw gas out of the tank by siphoning on the hose as well. I have also tried using a small 2 gallon tank as well by dropping my tank hose in there as well.
After searching through forums and parts diagrams, I don't think this motor had a push rod for the fuel pump. It appears to ride on the cam. I also didn't see a rod in the opening. Supposedly, it worked fine the last time the previous owner had it.
I am going to grab a new filter for my separator today. Does anyone know if I might need to prime that filter first? The fuel line runs about 3-4 feet from the tank to the filter/separator and then another 5 feet to the pump. The filter size is a Sierra 18-7845.
Thanks for any help here!
