No Gas
freelunch
Hello everyone, I got my boat put back together and took it out yesterday however, I have a problem. When I started the engine everything ran great but when I went to full throttle it bogged down, after looking at the carb I found out im not getting fuel at full throttle. After about 1/2 way on the throttle the fuel cuts out and wont accelerate anymore.
My boat is a 18' 1972 Sea Ray Bow-rider with a 4.1 Mercruiser 250 inline 6 and a Rochester 2 bbl carb. What would cause this?
waterdawg69
Re: No Gas
did you check the fuel pick up line sometimes it will get clogged and fuel filter
Re: No Gas
Ayuh,.....
It Could be anywhere between the Fuel Tank,+ the Carb.......
I'd start with the Fuel Filter,+ Go from there.......
freelunch
Re: No Gas
While out yesterday I replaced the fuel filter, the old one was pretty dirty. But when i pulled the upper housing of the carb off afterward the fuel bowl was maintaining plenty of fuel in the carb. Even so its still not giving me gas at full throttle.
Re: No Gas
Ayuh,........
It's possible that the Carb is Plugged, Internally............
ziggy
Re: No Gas
or perhaps since ya've had the top off yer carb. yer float level got out of adj. or needs adj.....there's a spec for that.......there's also a screen type filter where the fuel line hooks up to the carb. i've found debris in mine that get's past the fuel pump filter....i had a coil breakdown that also acted similar to what yer describeing...that only acted up after the engine was warm though......
