dajohnson53
Thread starter- Joined
- Apr 28, 2004
- 1,627
Hi: I bought a used, low hours, very clean 19990 J200TXESM last fall. At the time, I ran it for about 6 hours over 2 or 3 sessions to just check it out and empty my fuel tanks so I could fill with fresh for the winter. The fuel was premix 50:1, but the engine is VRO2 and the oil use from the oil tank was perfect for the amount of fuel burned. I was (and am) happy with the starting, idling, top end, etc. It runs great.
I know the "low oil" alarm works because I ran the tank down to about 1/4 full and I got the proper alarm - beep every 10 or so seconds.
This spring, before running it, I replaced the oil hose from the fuel pump back to the tank, replaced the oil pickup filter, made sure fuel and oil hoses were OMC ratchet type clamps and that they were nice and tight. I primed the oil line. I've only run it for about 2-3 hours, but all has been perfect.
Recently, it's been sitting for about a month. I started it up last night to test some new gauges I installed and after about 5-10 minutes at idle on the hose (with good water flow), I got the "no oil" alarm. It was definitely a very regular beep every second - not an overheat or fuel restriction alarm (which I've heard with my older V6 engine).
I re-primed the oil line, making sure to get all air out of it - I pumped about 8 ounces into a jar and carefully reconnected, then pumped the oil bulb once more. I looked carefully at all oil line connections and they all look good, no signs of leaking. I started it and idled on the hose for a good 15 minutes and did not get any alarm.
So my question is: Is it at all normal or common for the oil side to require re-priming every now and then? If not, what else can I look for?
Thanks.
Thanks.
