No power to electric fuel pump
I have a 2005 Yamaha F90 TLRD that is not getting power to the electric pump in the vst tank. I have replaced the pump and it is working but I can't seem to get power to it. The fuses are good and I have power to turn the starter. I can't see any damage to the wiring but I have not dissected them and don't want to. I'm leaning toward the ecu but don't know. Any suggestions would be greatly appreciated. Thanks
99yam40
I believe the pump gets power at key on, but the ecu tells it when to rim by completing the negative side.
so, are you getting 12V + at key on?
No, used a test light on the connector and got nothing when I turned the key on. Used a battery and jump wires to know the pump is working.
boscoe99
The ECU does not provide battery power to the electric fuel pump. Battery power is from the fuel pump relay.
