Hi, I have 1998 Bayliner Capri with a Force Outboards (85HP) from US Marine Power. I tried last Saturday in the small lake and it runs well. The only problem is NO reverse and when I start on neutral, it goes forward slowly. When putting the Throttle Lever on reverse, it goes forward also with high acceleration. Anybody can guess what the issue is please?
I also replaced the bottom gear oil. There are 4 screws (Vent screw, Fill Screw, Drain Screw and the Shift Pivot Screw). By mistake, I also removed the Shift Pivot Screw and was hardly to put it back. Do you think problem for not reversing is because of the Shift Pivot Screw? Thanks for your help on this.
