No Spark
snowman33
i have a 65hp mercary serial #4269783 i think the i have a problem in the key switch i have 12 vt on the red @ white wires with the key off. with key on the vt are 0 if i unhook the harness and there is 11.5 vt on the red @ white. so how can i start the motor with the harness unhooked or can it be done ? thanks
Laddies
Banned
Re: No Spark
On the starboard side of the switch box jump between the red and the white terminals
snowman33
Re: No Spark
And this will let the motor start? and if it dose run that means the key switch is bad?
snowman33
Re: No Spark
Laddies
Banned
Re: No Spark
Yes that effectively bypass the ign. switch. Heres a simple test for you system.
