pete44
Thread starter- Joined
- May 7, 2005
- 189
'87 searay with 3.0 litre Alpha 1.....Converted from breakerpoints ignition to electronic...wired as per pertronix tech support...turn key no crank just a grinding noise out of distributor...(like not enough juice/voltage going to it...)...wired black of pertronix to negative of coil...wired red of petronix to electric choke side of purple "resistance wire"...spliced right before connector that plugs into electric choke.coil wiring is way it was wired originally with original distributor setup...engine did turn over before (just no fire) when it was wired different...(I am thinking seriously to go back to points!)...Any help appreciated....Pete
