Occasional beep what is going on
zarillus
110HP Evinrude 89
Occasional beep when first starting up first few minutes then okay??
nwcove
Re: Occasional beep what is going on
new to you motor, or new to you beep? some system check setups do beep when first starting.....just to let you know the buzzer works.
boobie
Is this mtr original or has it been converted to system check ??
zarillus
new to me motor on initial startup runs great for few minutes then i get a single occasional beep sometimes.I am thinking about the VRO possibly going bad?? Do they just stop working or do they slowly fail? I like it and don't want to mix the gas and oil
boobie
For testing purposes. Disconnect the wires from the oil tank and start it up. If the beeps go away that's the prob. Next disconnect the wires from the vro and see what happens. That way you can narrow it down to what is causing the beeps.
zarillus
thanks i will try that and let you know that results
emdsapmgr
When first turning the key to "on" the horn should beep once, to indicate it is working. An intermittent beep (every 20 seconds) means the oil tank is low on oil. A beep every other second means there is a problem with the oil pump. Disconnecting both these items is a valid (temporary) test procedure. Keep in mind the horn itself can also be the problem.
