Oil cooler
BlowHo
I have an oil cooler system, is it critical or can I just screw an oil filter directly to the block?
Acer2428
Re: Oil cooler
Why would you bypass it if you have it?
Anything to keep your fluids cool is a good thing.
BlowHo
Re: Oil cooler
The adaptor split and I'm having a hard time finding a new one. Just curious mainly.
BlowHo
Re: Oil cooler
Anybody?
OMC 460 with King Cobra. Just had the motor rebuilt and the crack in the adaptor was found during rebuild. The mechanic said his advice would be to scrap the oil cooler since I had a lot of metal shavings in the pan that might be trapped in the lines. He said the motor will run cool enough that the oil cooler isn't necessary.
The adaptor is expensive and hard to find (In stock anywhere) Will a direct oil filter do any harm or do I just need to watch the temp?
180shabah
Re: Oil cooler
Have you checked an auto parts store, or even online at places like JCWhitney???
180shabah
Re: Oil cooler
TransDapt makes one and summit sells it for $34.39
PN TRD-1313
It fits Chrysler and Ford V8's, it is 1 5/8" thick and has a 3/4-16 thread.
The inlets/outlets are 3/8" NPT
BlowHo
Re: Oil cooler
180Shabah - U Da man! I get so wrapped around the difference between auto and marine that I did not check automotive houses. Thanks!
180shabah
Re: Oil cooler
That stack of catalogs come in handy once in a while.
