utexasrick
Thread starter- Joined
- Apr 25, 2011
- 46
I have rebuilt 4.3, 2 barrel, on a 97 sea ray. original block was cracked. I noticed a small oil leak near the starter with also a small amount of smoke. It's seems like its spitting out a small amount of oil and smoke from this hole near the oil pan which I though would have been blocked off by the oil pan. The worst case scenario that I can think of is if I'm getting blow by on one off the cylinders and causing pressure to build up in the oil pan causing the spitting action. I'm also getting a small amount of smoke coming from the valve cover vent tubes.
Previous I was having an issue with the engine dying at idle which was due to a fuel pump issue. Engine has not over heated though. I also have a small leak from the oil pan and timing chain cover so I think I'm might just have to redo the oil pan.
Anyone know where this hole on the block next to the oil pan leads to? I didn't notice it when installing the oil pan
