oil leaking all in upper cowling
Mcabala
hello everyone
i have a 2005 mercuy 90hp 4 stroke and i recently changed out the whole water pump and did an annual service.(oil/filter-spark plugs-water/fuel filter).after doing everything i hooked up the water to the lower unit started thye motor up and let it run for about 10 mins and walked away.when i came back i noticed there was oil on the ground so i quickly shut everything down.i noticed that there was oil on the ground and the upper cowling was filled with about a Qt of oil which started to leak down,i have no idea whats going on or what couldve happened.looking to see if anyone on here had a same issue or close to it or knows any answers
Faztbullet
Check oil filter for correct sealing and possible double seal rings..
flashback
I've run across filters that were defective and would not seal. Maybe try a different brand.
