Oil pressure sending unit upgrade
Jakem
I would like to upgrade this old unit. 70s Ford 302. Is there a simple switch available
achris
More fish than mountain goat
That is the same as is currently used...
Jakem
Alright thanks. I will just replace it
Is there something wrong with the sender, if not, spend your money on things that need replacing
Jakem
I'm replacing almost everything to avoid any falts on new engine. I'm tired of breakdowns
achris
...70s Ford...
.... I'm tired of breakdowns
Get use to them... You're up against the 2nd law of thermodynamics.
I went through the same thing with my old 165, the solution was a completely new drive line. ie, If you want 'more reliable', get something much newer.
Chris....
Jakem
I have a new engine coming it's just a waiting game. Wich sucks as all the sturgeon boats are starting to show up on the river lol
achris
It's not just the engine, it's the drive and gimbal housing too.
Chris....
Jakem
I know and so far there's been no issues there. It all looks and operates as it should so far
Jakem
What is the reason for 2 sending units
Jakem
Not that I have ever heard and my oil pressure went as low as 20.
achris
You have a big red 'WARNING' light on the dash. That oil pressure switch is connected to that light. And as Scott suggested, it's set at around 7psi. It comes on before the engine is started?
Chris.........
