Fiat4Fun
Thread starter- Joined
- Sep 14, 2009
- 229
Hi there,
Had a great day on the lake today with the boat, thanks for all of those that help get that pesky water temp sending unit out. Use the right tools, and work is easier! Gauge worked fine.
So, I was thinking that maybe the oil pressure sending unit is OEM. The boat is a 1986 CC 210, with a 260hp Mercruiser, Alpha one.
What type of oil pressure should I be seeing???
It shows around 40lbs @ 5000rpm ( full throttle) and I was think that you should see 10lbs of pressure for every 1000 rpms. Maybe the old sender is not accurate?
How often do these things need to be changed? Any advice is greatly appreciated and I hope you all have a great weekend.
Bob
Bob
