Wotknot
Thread starter- Joined
- Aug 6, 2002
- 310
Went outside to put a new slave solenoid on my 2000 Merc 3.0 engine. Ten minutes job, right? After disconnecting the battery, I disconnect the wires from the solenoid and then get a 7/16 socket and begin to loosen the 2 nuts holding the solenoid on. That's when I notice I'm getting no where fast.
Ok, get a flashlight and then see 2 brass nuts behind the electrical mouting plate that needs to come loose. Only thing is, the mouting plate has to be loosened enough to get a open-end wrench in there to hold them. No problem, just loosen up the electrical mounting plate, right?
After studying on it, it appears the 2 star-headed nuts that's holding the coil on are the ones I need to loosen up, but ...... I tried a 12 pt 7/16, 3/8, and 10 mm but none fits so I'm "assuming" I'm going to need a star socket ......but what size?
I bypassed taking a nap this afternoon just to try and get the sucker on .... man that sucks.
