yt
Thread starter- Joined
- Jul 9, 2009
- 72
Hi all. Inherited an old boat with this 80hp Merc. Have worked on cars before. It sat for 3 - 5 years. Luckily the battery only needed a charge and was still good. Took off the cover and some of the wires were really brittle. Especially the small one for number 4 which I think is from the trigger? Insulation cracked and came right off and the copper looked a bit green so I very carefully wrapped them with some electrical tape for the test. Got a flush kit connected to the hose. Mixed up some fresh fuel with just a touch extra oil since it sat so long. The motor started up on the first crank. Ran a little rough, maybe just the extra oil or a misfiring cylinder. Bottom unit lube was good and it shifted OK.
So is the a way to repair or replace any of that wiring without pulling the flywheel? What else might i need to look at to get this thing running smooth again while I decide whether or not to sink money into a new transom and floor for the boat.
tnx
tnx
