omc 4.3 starcraft
medalist1901
ok, i got another question... I have a 1988 Starcraft medalist 1901. i just bought it and as it turns out the crank case is fool of water, and one of the heads has a crack, and two of the freeze plugs aree missing:( It has an OMC 4.3l. However, I do have a few good 4.3l automotive engines. Can anybody tell me what the diff. is between the two engines, or what I need too change?? Thanks, Bryan
a70eliminator
Re: omc 4.3 starcraft
Your 4.3 long blocks will work fine, you'll need to swap everything from the oil pan to the carb including the cam, brass freeze plugs are a + too.
Dakota47
All you change is freeze plugs if its a Truck motor. use the marine carb.:D
medalist1901
do I need to swap everything internal. or just the carb & the oil pan, and sone brass freeze plugs???
a70eliminator
Oil pan and pickup tube
carb
distributor
motor mounts
starter
crank pulley
flywheel
exh mfds
It's all doable without having to open the engine
