Omc Cobra fill indicator gasket
A1957
Has anyone come up with a better gasket or oring for the level indicator on the top of a OMC Cobra outdrive? I've replaced mine twice and twice it’s leaked. There has to be something better than the overpriced plastic washer from Johnson/BRP.
hugh g
Are you also changing the ones for the fill & drain plugs? Maybe it's not the dipstick that's leaking. I used to change all 3 every spring.
A1957
Yes, I’m changing all three. But the top one keeps backing off and (I assume) letting water in.
