Omc Cobra Overheating Helppp?????
Status
Not open for further replies.
newtoboatsmarc
Hi i have an omc cobra 4.3 setup that is overheating. we have changed the impeller thermostat and have cleared the waterways. when the boat is in the water it will over heat with no water getting from the impeller to the thermo housing unless we give it big RPMS. the boat will run at home on a hose with no promlem. we have flushed all the waterways and they look ok can anyone help.... something i not to sure of is should the impeller housing get hot?
Re: Omc Cobra Overheating Helppp?????
Nope,.... My WAGuess is,... It didn't get water the 1st time you started it,+ Now the impeller is Junk again...
danond
I agree with Bond-o. You can't ever run a sterndrive boat without a water supply. The people who run their I/O's on the trailer to "clean it out" are doing it wrong.
The impeller/pump in the drive relies on water for a lubricant, and a number of exhaust components can't take the heat generated by uncooled exhaust air. Without the lube, it heats up and deforms within seconds.
newtoboatsmarc
thanks for the reply the impeller looks ok how can i check that it is or should i just get another?
jpwdesigns
Threads like this are killing me because i have the same problem and there's no solution!!! Please Please Iboats people, post your solutions for God's sake.
Ayuh,... So quit postin' in the archives, 'n post yer Own question...
Status
