tmfeaster
Thread starter- Joined
- Jun 22, 2011
- 94
I currently have an active thread about my boat/engine (http://forums.iboats.com/showthread.php?t=489522). This thread details issues for repair after an overheat.
Before the overheat my RPM Tach did not work. Since I am near the end of fixing the engine I just replaced the tach with a brand new one because I had already replace the stator and rectifier/regulator (NEW).
I have tripple checked and the wiring is correct but the new RPM Tach doesn't work either. When I opened it out of the box the tach was at 1100rpm but as soon as I installed it and hooked up the battery, it dropped to zero and has been stuck there since.
Any ideas on what I can check next?? The regulator/rectifier I bought had instructions that said it didn't matter which yellow wire went to the stator yellow & yellow/silver wires. Is that true?
Any help is greatly apprecaited. Outside of one muffler gasket this is the only thing left on my boat that doesn't function. Of course, new upholstery is next
