Re: OMC electric shift slipping
Sorry for the delay, Just had to go fishing before the boating season gets started.<br /><br />In any case. From what I remember, those were simply (Borg Warner) Velvet Drives, with an electric shift mechanism... You can certainly convert a Velvet Drive to mechanical(cable) shift.<br /><br />If it isnt an electrical problem, and the shift lever is working, then you have a hydraulic/friction plate problem.<br /><br />Does it slip in both gears?<br />if so, probably either the oil. the pump, or the valve. To know what is wrong you'll need a pressure gauge. (0-200psi) The pump should be capable of 150psi or so. <br /><br />If just in one direction, then you probably have a clutch plate problem. <br /><br />There are good used and remanufactured transmisions all over the internet.<br /><br />Hope this helps, Good luck !
