Re: OMC Guru's---Dhadley, Walleyehead, anyone....
Walleyehed-- Let me get this straight. My timing advance screw has two slots for a screw driver. There is one under the rubber stopper and the deeper slot on the opposite side where I am making my measurements. I am assuming the side that you should turn as far as the Clockwise/CounterClockwise is concerned is the side opposite the rubber stopper where you measure? Is this correct?<br /><br />I was trying to verify timing tonight, but I had two problems. First off my eyes got dialated today at a doctor appointment so I wasn't seeing very well. I couldn't get an exact reading, but it looked like my timing was reading 20-22. The timing gun I had has a setting where I can put in a timing # and it should read at 0. So I put 28 into it and it was reading 8. Does anyone know if this means it is to advanced or to retarded? I am assuming if I was reading my 20-22 that the 8 reading means I am 8 degrees retarded. Heck who knows I guess I will try tomorrow when I can actually see. <br /><br />Is it safe to set timing on muffs as long as you are in gear and have a lot of water going through the engine? This would sure be a lot easier.<br /><br />Thanks everyone!!
