Re: omc outdrive shift problems
butch,let us know what you find.My only guess at the moment is that reverse gear has moved back in the gearcase,towards the prop.But that is a Merc problem.With your Cobra,bolts would have to loosen,snap rings break,etc.<br />Did you have this problem before the cable work? Was the drive apart before this problem?If so,maybe the forward snap ring in the gearcase did not seat.That could do it.<br /><br />DHP
