Re: omc question?
It will work, the only minor thing I can think of is that the manifolds are a bit different on a 3.0, and may or may not exactly match where the riser meets the downpipe. Might work, might need some creative engineering. <br /><br />If you go with a ~1990 or later 3.0 you will also need a new coupler and flywheel since the crank changed then. Pre-1990 should be fine with what you have. <br /><br />That should be it.
