HI
new to site, my family want to purchase a 81 sea ray with a omc 800 stringer gear drive. the boat is in good shape, except and the owner told us. that there are times. the out drive would not tilt up and down. And he would manually loosen 3 bolt and manually raise the drive. also in the process his 50 amp fuse would blow, and the fuse will need to be replaced and once the fuse is replace it may tilt again, and work normally. during the viewing of this boat. the tilt operated just fine, it went up and down. but the owner said, it will work perfectly but there is also a 10% chance that you will blow a fuse and the tilt will not work and that maybe the time when you are at a ramp and trailoring the boat. what are my chances of fixing this type of issue. The owner suspect that it is the gear box assembly, that runs the half moon shaft gear that lowers and raises the unit. like i said " he suspect". could he be right? or is it something else, What would blow a fuse, so obviously if the fuse is blow then there could be some fault electrical unit issue. and the tilt motor would not work, so i need help. please advice. any information is greatly appreciated
