OMC Stringer Gear Lube?? What kind?
Status
Not open for further replies.
DukesFin
Need to replace the gear lube in upper and lower units...
What do I use? I doubt that "OMC Premium Gearlube" is still sold... Anyway, I'm wanting to go pick it up today too, so a good "replacement" product that is readily available would be great!
Thanks!
fendersfender
Re: OMC Stringer Gear Lube?? What kind?
I still buy OMC HI-VIS gear lube at my local marina
DukesFin
Is Type C appropriate for Upper Unit as well?
How many quarts do I get to fill both Upper and Lower Units?
bruceb58
If you have an electric shift, you don't want to use Hi-Vis. Says right on the bottle not to use in electric shift models.
Sierra carries a type "C" lube. Its part number is 18-9600 and can be bought in various quantities.
What year is your OMC?
DukesFin
'77 Lower Unit and '74 Upper...
Yep... No HI-VIS for me. Type C it is. West Marine carries it locally.
DangerDan
I use OMC Ultra for the upper and premium blend for ther lower.
Status
