Serf27
Thread starter- Joined
- Aug 23, 2018
- 167
I have heard a thumping noise from the rear and I think I felt it too.
It’s only happened 3 times and it happens fast enough to where I can’t pinpoint what’s really going on.
Best I can describe it as is:
The thump/feel feels like when you’re lowering/tilting the drive into position until you feel a slight tap against the intermediate housing, knowing it’s all the way down.
That’s what I feel/hear.
When it has happened, 3 times.
When on plane, at about 3k rpm, I will ease off the throttle for whatever reason and then give it throttle and this is when I hear/feel it.
I have read it may be a worn dog clutch or the propeller?
The shift cable was installed as the manual says to do so, neutral and all other adjustments that where in the manual where done, fluid in upper/lower/intermediate are all new.
I haven’t drained the lower drive oil yet to check for metal shavings.
Could it be a prop issue since I THINK it is happening when slowing down for a second and then taking off?
The drive shaft between the upper and lower look, good, no missing teeth/splines.
No noise when cruising on plane or when shifting in/out of gear or in wake zones.
Thanks.
Thanks.
