Omc thermostat housing
diverpat
Hello all, I have a 1973 350 Chevy/Omc outdrive, I bought a thermostat housing from a Ford Omc set up. My question is on the ends where the hoses go to the exhaust manifolds have a real small opening, the engine (brand new) to me seems to be running a little warm, between 160/180, do all the housings come with such a small opening, can I drill it out bigger, will that cool the engine due to more water circulation thru engine, any help appreciated...thanks
Re: Omc thermostat housing
Ayuh,... Welcome Aboard,... Have ya changed the raw water Impeller,..??
That's Always the 1st place to look in an over-heat situation...
'n,... OMC has used a Bunch of different T-stat housings over the years,...
Most all are different, 'n the normal approach is to put back on, Exactly what was there...
Can ya post pictures of each,..??
Jammer864
I know the outlets you are talking about. Mine are much smaller too. About the size of a pencil, I would say. I doubt thats where your extra heat is coming from.
EDIT: The holes in the outlets are about pencil size, not the casting itself. OK, maybe larger than a pencil, 3/8ths of an inch maybe?
