OMC Tilt/trim sensor
chaparral1990
Can anyone help me locate a tilt/trim sensor switch for my 1990 OMC 5.0 HO engine/Cobra sterndrive? Engine model number is 502APRPW5. Thanks.
Lodgepole
Re: OMC Tilt/trim sensor
might try marineengine.com
part # is 0984748 $119.95
These guys furnished me a vintage 1992 trim guage (OEM)
havasuboatman
Ensign
It's on the starboard (right) side of the transome assy. It bolts on the inside of the gimble ring. Hard to see, but that's where it be.
chaparral1990
Thanks for your help. I will contact marineengine.com and see if they have this part.
a70eliminator
Good luck with that, let me know if they do in fact actually have them, I would be surprised. I ended up building one myself with the old housing and arm with a new radioshack potentiometer of matched values, one whole season on it so far so good.
cdnboater567
Hi, your fix sounds like the only viable solution given lack of parts. Could you provide the details of the parts you used and any hints for the assembling and waterproofing? Many thanks!!
danond
a70eliminator - you need to pony up how you did that, man! I need the same fix.
wildboater
Just a comment. Your engine model number is 502APRPWS, not PW5. I've got a '91 Chris-Craft with a 1990 574APRPWS. I had to get real close to the engine model plate to get the number right. I read it as a '5' at first and couldn't find anything anywhere. Change to 'S'...all kinds of info.
