redfury
- Joined
- Jul 16, 2006
- 2,659
Re: Ooo! Sparkly! Redfury's Grinding again!
Up, up and away!
The plan is to slide the trailer under the boat and support it with wood blocks.
Ah, the aqualift 2 hull. This is the only time I want to see the bottom of my boat though. I'd rather enjoy the ride from the hull than enjoy the sculpted abs of my boat.
The smaller Maple tree held up beautifully during the flip also. To think that I almost cut this little guy down!
Getting the boat down ended up being the harder part of the process. The ratchet goes down one click at a time ( or more if you work at it ). The rear was pretty easy. Getting that logging chain off the front was a pain.
I got the rear of the boat situated pretty good on the trailer, and attempted to reverse the process in which I got the nose up in the first place. Didn't go as easily. See, the crank for the boat is on the tree side of the trailer and the trailer was wedging up against the tree and I couldn't run the winch handle very well. So, I ended up using an improvised car bumper jack my dad had done some "work" to, along with a piece of plywood that I had done some "work" to, to extend its range. With those, I jacked the nose of the boat up a bit from underneath, enough to remove the bolt and settle the hull on the suspended trailer. Then with some finagling, I got the boat cranked back to earth.
Then it was a matter of leveling the bow and stern so it would ride of the trailer without shifting or falling off.
2x3's I had laying around from my dad when he moved. Cut them to lengths that would work and I now have a nice surface to work on. I might even see paint on this beast before winter?
Up, up and away!
