oregonboatnewb
- Joined
- Dec 6, 2008
- 283
Re: OOPS Lower unit water hose Came with it ?
Also should i grease the copper tube, or leave it bare.
Can't really say for sure if the orientation of the reverse lock cam is correct or not. The orientation depends on what gear the L/U is in. IF the unit is in reverse, then I would say the cam is oriented properly.
That cam (when in reverse) pushes up on a rod in the midsection that actuates the reverse lock clamps on the transom mount. Prevents the motor from kicking out of the water when revving in reverse.
As for lubing the water tube, I always apply a little waterproof grease to easy assembly and reduce corrosion. Not saying thats right or wrong.
Note that the tilt-lock is also engaged when in Neutral.
Best way to get the cam on correctly is to be shifted into Fwd gear.
Turn the driveshaft clockwise (as you look down at the lower unit). The prop should also be turning clockwise.
Then, rotate the shift shaft CCW to shift into Neutral. You'll feel the detent as you're moving from Fwd to Neutral.
Use a pair of suitable pliers or Vise Grips to turn the shift shaft. Put some tape on the plier's jaws, or cushion with a rag, so you don't damage the splines on the shift shaft.
Now, move the shift shaft in the CW direction to shift back into Fwd gear. Only move the shaft as much as is needed to get to Fwd. This won't be much motion at all and you'll feel it dropping into Fwd right away.
Note the position of the shift cam as it relates to the shift interlock rod which is sticking down from the rest of the motor.
If the cam is positioned correctly, the interlock rod will be pointing to a position approx halfway up the ramp of the shift cam. Pull the cam off and reposition as necessary to realign.
Note that with the splined shaft and cam, you'll either be Right On, or Way Off. No in-between.
You'll find that with the interlock rod pointing to halfway up the shift cam's ramp, that when you shift to Neutral the top of the shift cam blocks the rod from moving downwards, which locks the hooks around the tilt pin.
HTH.........ed
