Operating Temperature
Beefer
I've combed through my engine's owner's manual, checked every spec listed in the Seloc, and read gobs of posts here, to no avail.
I have a Mercruiser 488r (aka 170), and I'd like to know what the proper operating temperature range is for it. Most of the time she runs right at 160*F, but it gets up to 180*F after about 2 hours at 3500rpms. Hasn't run hotter (yet).
Just wanting to know at what temp I need to worry, and the books aren't helping....
Alpheus
Re: Operating Temperature
Those temps are absolutely normal ( if thats the correct temp for the thermostat you have installed) and you have nothing to worry about. 20 deg F after 2 hours of running almost WOT. Relax and enjoy your perfectly normal operational 470. You are one of the lucky ones...
http://forums.iboats.com/showthread.php?t=418315
PS
Ditch the Seloc and get the REAL manual. This is for the 85 and up but its a start...
http://www.4shared.com/document/gh-PNxn3/Mercruiser_Service_Manual_8_19.htm
Beefer
I found (in the manual from Alpheus) a little note that the normal operating temp is between 165* and 200*.
nola mike
when did the manuals come back?
i installed a thermocap on mine, which reads ~30' higher than my gauge. i run at about 180', a little higher when skiing.
