Merc115_1988_6_TS
Thread starter- Joined
- Jul 22, 2019
- 11
Greetings. Re-joining the forum after a long absence. None of y'all tell my bride that I'm back in the business.
Bought a toy off of Craigslist and could use some help. 18' bass boat had been sitting outside for a couple of years. Had to air up the tires to bring it back to my shop. Needs new carpet and upholstery. Hull is sound and looks good mechanically. Didn't start the engine but I'm hopeful. How could I not buy it for $800?
Haven't started the motor yet because I'd like to drain the gas, clean the carbs, lube it, and check the hydraulic fluid before cranking it up. Also thought I'd pull the plugs and do a compression test. Probably squirt some oil in the cylinders afterwards. Anything else I should check or do before starting it?
Anyone have a link for the Operation and Maintenance manual? And/or for the Service Manual? The sticky links do not include the 6cylinder 115 two-stroke (at least I can't find it). Haven't been able to find a reputable source for soft copies of the manuals. Hoping someone will take pity on me...
