Outboard motor stands
mrsalmon
I have been looking and reading a ton of threads and have seen motor stands that look home made and wondering if there are any threads on building one. thanks
skipper711
Re: Outboard motor stands
Just had a look at the link above and if your good with wood that is your answer, I have made a good many all out of angle iron and welded together because that is what I did in my working life.
However, I did make one out of the drilled angle steel that forms part of the dexion storage shelving, all you need is a tape measure, hacksaw and some nuts and bolts. You can make it whatever size you need.
Normally most scrap yards have a fair share of this type of shelving.
Good luck.
Davem3
they are easy enough, if you want send me a PM and i will shoot you a picture of mine, i used scrap wood i had lying around :)
EDIT:even better, here you go ..................
just 2X4's and a 2X10 for the back .............
