Re: Outboard mounting height 1985 Johnson 115 v4
the absolute EASIEST solution for you right now, which iis also one of the cheapest( meaning keeping the motor you have now) is to buy a manual jack plate for about $200.... it will allow you to set the motor at the perfect height....and even allow for future adjustments.
if you would go that route.... then id do that FIRST...
then you can see what the final rpms are when you have a more ideal motor trim-boat relationship.
and if needed you can purchase the correct prop for your needs
it could be the waters drag on the lower unit...but you should be running about low 5000's with that pitch and such a small boat?
how heavy is the boat? is it possible it is ladened with excess water in the flotation?
in any case... moving down to a 15 pitch is a possibility......and id say do it...if you are NOT GOING to buy the jack plate
your rpms should be between 4500-5500, so you are not far off.... if you got the rpms up to 5500, and got rid of the drag on the lower unit..i bet youd be running 41 mph or more.
its your call...but for the health of your motor, id get the rpms up past 5,000!
if you do that...and dont do anything else...the worst thing is you are burning more gas than needed, and you are not going as fast as you could.
here at IBOATS...they say ONLY ONE LEFT!!
better hurry ha ha ha
http://www.iboats.com/T-H-Marine-Hi...55729940--session_id.407629075--view_id.40132
bob
