Outboard trim pump wont work
quarterhorse99
Have a 1979 merc 115hp that has an outboard trim pump. There are 3 wires that have been cut a blue, green,and purple wire that run to the trim controls on the throttle. Any idea on the wiring for the trim pump end?
rosser1
Re: Outboard trim pump wont work
on my boat the green and blue go from the solinode to battery, i hane a inline 6 1978 mariner should be close, but it will made a difference if green is hooked to positive on battery it may run backwards so then reverse wiring. good luck
