- Joined
- Apr 17, 2002
- 71,545
Re: Outdrive hole cut with transom in boat
If you've got a full transom board that's 2" thick,...
That little shim piece is Unneeded,+ will cause coupler failure, because the transom will be Too Thick...
The Finished transom needs to be 2", Overall Thickness...
I got the terminology right. Transom...the whole sheet of 2 inch sheet of plywood. Bolt it in to aluminum skin
