Outdrive not working
SuperMiguel
I removed the outdrive from my boat to change the gimbal on it.. and now the outdrive wont move, its like the shaft is stuck... is there some kind of security mechanism that would prevent the shaft from moving? Thanks
Don S
Re: Outdrive not working
What are you working on?
What do you mean won't move? Left and right? Up and down? fwd. and rev.?
What shaft?
Fishermark
And what gimbal did you replace? Gimbal bearing? Gimbal ring? Something else?
SuperMiguel
both the bearing and the ring, and that part that wont move is i think is called the Yoke is that part that goes into the engine coupling
the part this guy is holding with his hands
Don S
Yes, it's called a yoke, Do you mean that it won't turn when the guy holding it tries to turn it by hand, or that it won't turn while on the boat and the shaft in the coupler.
If the latter, look through the gimbal bearing into the coupler and see if the spline are still in the coupler.
Don S
If you can't turn that shaft by hand, you have big time drive problems.
Disassemble and inspection of the drive is the next step.
SuperMiguel
When i removed it to replace the gimbal by mistake i removed all the drive oil.. Will it still turn if it has no oil???
