Outdrive
ermrtn
How do you check an outdrive to make sure it is good and not junk?
Howard Sterndrive
Re: Outdrive
question is too vague.
anything from "waterski behind it for several hours" to "drain and inspect the lube" would be a correct answer.
you're looking at a used one?
make and model?
ermrtn
Re: Outdrive
I have an outdrive that is on a boat with no motor. Before I take the outdrive off to replace outdrive on another boat I was just wanting to know if there was any way to check it before I do all the work.
Howard Sterndrive
Re: Outdrive
being all secretive about what make and model buys the ol' *unsubscribe* from me- good luck....
