How do you check an outdrive to make sure it is good and not junk?
E ermrtn Recruit Joined Jul 18, 2010 Messages 2 Jul 18, 2010 #1 How do you check an outdrive to make sure it is good and not junk?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,510 Jul 18, 2010 #2 Re: Outdrive Short of dis-assembly and inspection you can`t.
Howard Sterndrive Rear Admiral Joined Nov 5, 2008 Messages 4,603 Jul 18, 2010 #3 Re: Outdrive question is too vague. anything from "waterski behind it for several hours" to "drain and inspect the lube" would be a correct answer. you're looking at a used one? make and model?
E ermrtn Recruit Joined Jul 18, 2010 Messages 2 Jul 18, 2010 #4 Re: Outdrive I have an outdrive that is on a boat with no motor. Before I take the outdrive off to replace outdrive on another boat I was just wanting to know if there was any way to check it before I do all the work.
Blk-n-Blu Master Chief Petty Officer Joined May 12, 2004 Messages 821 Jul 18, 2010 #5 Re: Outdrive Might want to look here: under How do I: http://www.mercstuff.com/
Howard Sterndrive Rear Admiral Joined Nov 5, 2008 Messages 4,603 Jul 18, 2010 #6 Re: Outdrive being all secretive about what make and model buys the ol' *unsubscribe* from me- good luck....
