Over Heating And Water In The Oil
TOMMYO8
Re: Over Heating And Water In The Oil
thank you for all ur help i used the heads from the automotikve moter cause they already had the roller rocker arms i think i will remove my heads and get the orignal put back on there and see how they do after i get them checked at the machine shop this shop is really good they have a good rep with boat motors i will have my heads that came off the original motor and new gaskets put back on and then see what it will do thanks again for all the info. Tommyo8
HT32BSX115
Howdy,
It appears that you might have either another bad impeller or remnants of a previously failed impeller blocking water flow. Is there a power steering and/or oil cooler in the raw water line from the transom to the engine? If so there may be blockage in one of those oil coolers.
They may pass enough water at idle but be insufficient above idle or at higher power settings..
Also, you said that you welded one of your riser/elbows. That is pretty risky at best. It does work but it only works for the exterior of the cast iron piece.
If there's a crack in the interior you'll never know it until you start hydrolocking after shut down, or at the beginning of next season when the engine is frozen from raw water corroding up the cyls that had open exhaust valves at the end of last season.
If they're not leaking now, you should replace them soon (this year) or you may be replacing the engine again.
Good luck,
Rick
kandil
do you have the right spark plugs for this motor that could cause the motor to run hot.However I think you have a blown head gasket if you have water in the oil or if you run it in a barrel and find oil in the water good luck
TOMMYO8
:confused::confused:ok this is to weird,i changed te oil yesterday and hooked the muffs up and no oil in water ?????????what the he%%ll is going with this??
Gary H NC
Its hard to get one up to full running temp on the muffs.
No load on the engine at all.
Did you pull the heads again?
TOMMYO8
No not yet. I was just curious to see if water would get in just running on muffs very strange
TOMMYO8
I did not pull the heads again i was just curious to see if water would get into the oil again sfter i changed it and it did not :confused:
