Re: Overheating...or not
Hello Capt,
A bolt instead of a stud..that's an idea. I'll gladly fight the stud again in 7 years if I can get this thing running.
Yes, I have gotten water out. Now it seems more of the spray. It has a red tinge going in so it's hard to guess if it's rusty coming out. Back in town this afternoon and decided to spray and flush some more. Still a bit paranoid about creating a spark. My fuel line is disconnected from the fuel pump and plugged with a spark plug. I have the coil wire from the coil with a Phillips head inserted tightly and clamped to ground with a vice grip. Can I assume a spark will be non existent? I run the blower and with all the BP sprayed I still get a faint fuel smell. Paranoid from an incident as a stupid teenager. I have been cranking some but would really like to go to town...
Went looking for a stud removal tool today with no luck. I realized I hadn't sprayed anything on the stud and if it was truly finger tight as it should have been I'll give the vice grips a try again. Focusing more on the water issue atm.
Gonna go crank some more, change oil, crank again. Gonna give that stud another go around now that I have some BP on it.
Thanks for the idea about keeping it lubed. Until I get the manifold, Ill go out daily and spray and turn. Sound right?
I'll get back in a little while.
Thanks again...Wish I could buy you a beer or coke or something...
