I have a 1986 Merc 150 blackmax. Took it out last week and was running like a champ. As I was loading the boat on the trailer I noticed that there was no water coming from the pee hole. The motor obviously got hot. I don't know how hot it got. I replace the water pump and the thermostats. the t-stats were the problem because they didn't open up when I put them in boiling water. I got everything back together and it took a while for it to get started. After it started it was no problem starting afterwards. However, It's not running like it should. It takes a while for the motor to rev up. I ended up doing a compression check and all cylinders were between 105 to 115. What else is likely to get damaged from the heat?
Thanks
Thanks
